Welcome to Club SAITO !
Old 02-02-2013, 08:27 AM
  #24126
nextofkin
My Feedback: (8)
Default RE: Welcome to Club SAITO !
3.5 X 6 mm tap use a number 33 drill
nextofkin
Old 02-02-2013, 10:01 AM
  #24127
blw
blw's Avatar
ORIGINAL: [email protected]
Hi, I would really like to be new member number 804.thanks
You are member #804
Old 02-02-2013, 03:18 PM
  #24128
stevegauth30
stevegauth30's Avatar
Thanks moderator man. 804 it is.
Old 02-02-2013, 04:15 PM
  #24129
mike early
mike early's Avatar
I wonder what the best speed prop for a Saito 82 on 15% Wildcat would be, APC 11x11 or APC 11x12...
Anyone ever tried either?
Old 02-02-2013, 05:21 PM
  #24130
Superspook
My Feedback: (16)
Looking for a glider launch rack or the plans to build one any info greatly appreciated Superspook in sunny Florida
Old 02-02-2013, 11:39 PM
  #24131
FNQFLYER
Re best prop for the 82.  I use a Bolly 12x6 on the 65 for vertical drag racing.  I would think the 11 size would be under proping it.  Try a 13 or 14 x 6 or 7 APC unless you can get a "go fast prop" like SAherlock and mess around with them.  You'll need a good tacho to make the ultimate decision.
I am lucky because with careful use I have enough Bollys to last a life time.  Result of buying up every one I could lay my hands on from here to right around Australia and then trading off for the ones I really needed.
Old 02-02-2013, 11:40 PM
  #24132
FNQFLYER
Re best prop for the 82.  I use a Bolly 12x6 on the 65 for vertical drag racing.  I would think the 11 size would be under proping it.  Try a 13 or 14 x 6 or 7 APC unless you can get a "go fast prop" like Sherlock and mess around with them.  You'll need a good tacho to make the ultimate decision.
Old 02-03-2013, 04:18 AM
  #24133
SrTelemaster150
SrTelemaster150's Avatar
ORIGINAL: mike early
You can plug some values into this [link=http://personal.osi.hu/fuzesisz/strc_eng/index.htm]STATIC THRUST CALCULATOR[/link]
If you adjust the RPM to yield the HP output of the engine, you can get an idea of what those props will yield.
On my big block Saitos it comes right in on factory HP spec's.
Don't forget to factor in te APC prop.
Old 02-03-2013, 05:19 AM
  #24134
Cougar429
Cougar429's Avatar
Superspook, sent U a PM.
Old 02-03-2013, 06:24 PM
  #24135
jw0847
ORIGINAL: jw0847
ORIGINAL: blw
I know that I've been behind in catching up with the Saito Club member numbers. Let me know if I forgot somebody.
792 JohnB96041
793 tarcure
794 jazzboy
795 108buzz
796 cperri
797 soliex
798 oldfartpilot
We are almost at 800 members. If you own a Saito and don't have a member number, let me know. I also take bribes, so send me any engines you care to box up.
Sign me up to the Saito Club - I have 2 Saito 100's in a couple low wing 60 size - one is a GP Escapade 61 the other a clone. I like the Saito because it just works and starts every time - no need to fool with it every time I go to the field.
Thanks - John
I would like to join Club Saito - Thanks John
Old 02-03-2013, 08:02 PM
  #24136
mike early
mike early's Avatar
ORIGINAL: SrTelemaster150
Looks like I'll be getting 110-120 miles per hour with a Saito 82 turning somewhere around 10,000 RPM static and an APC 11x12 prop on a Sundowner 36
Old 02-03-2013, 08:28 PM
  #24137
hsukaria
It will be a tight squeeze to put a Saito 82 in a Sundowner 36. It is a tight squeeze to put a regular-sized 2-stroke 40 in it. It would be interesting to see how you manage it.
Old 02-04-2013, 07:22 PM
  #24138
mike early
mike early's Avatar
I started with a Saito 56 with a 11x9 MA prop and it was wonderful. Only compensation was to put the RX battery back in the fuselage. Then I tried a Saito 72 with a 11x11 APC prop and it required some tail weight stuck to the bottom of the horizontal stab. It was faster and better. Then I crashed the plane with my Saito 82 and I figured why not, it's the same size and even less weight than the 72 so it's in there now. I have installed an APC 11x12 prop. 11 inches is about the extent of the ground clearance this plane affords.
I've added a polished aluminum spinner since this photo with the Saito 56...
Old 02-05-2013, 04:26 AM
  #24139
Rudolph Hart
Rudolph Hart's Avatar
Mike you are like a breath of fresh air to any righteous thinkin saito horsepower lover,takes a lot of thought to jam that much in there,it's the best plain out fun ever,safe too
Old 02-05-2013, 05:02 AM
  #24140
hsukaria
For a 2-stroke, Hangar 9 was recommending a 9x6 or 7 for the Sundowner 36. So, you installed the 82 inverted like you show the 56?
Old 02-05-2013, 09:05 AM
  #24141
SrTelemaster150
ORIGINAL: Old Fart
I have an FA91S W/CDI stuffed into a .40 sized US AIRCORE "Nighthawk" Turns a 15 X 5 @ 9700 RPM.
Old 02-05-2013, 02:32 PM
  #24142
FNQFLYER
Whats with these RPM's on these bigger models.  From memory some of them are barely making factory specs.  I know some of you might think the RPM's I quote for my engines are a "bit excessive" but for those in OZ I say go to an Old Timer meet and you'll see that my figures / performance is even considered conservative.  We run "factory sapecs" foor fuel and prop size (well all most) and get factory stated performance.  As an aside I have yet to come across any of the problems (FG20 carby aside, whic was fixed by a replacement one ex factory) that others seem to have with the petrol engines that wasn't operator induced.  Read the oinstructions / book there is a wealth of info and Mike Early, I would really like to see that machine with all the new engine types one can really get performance with a cubic capacity upshift without the resultant penalties of weight that we experienced in the past.  A bit like fitting a BDA Cosworth into the old Fiat 500 trick, and probably just as scary.
Old 02-05-2013, 03:18 PM
  #24143
SrTelemaster150
ORIGINAL: FNQFLYER
Whats with these RPM's on these bigger models. From memory some of them are barely making factory specs. I know some of you might think the RPM's I quote for my engines are a ''bit excessive'' but for those in OZ I say go to an Old Timer meet and you'll see that my figures / performance is even considered conservative. We run ''factory sapecs'' foor fuel and prop size (well all most) and get factory stated performance.
If you prop your engine for maximum RPM on the ground, it can over-rev once the plane gets moving in the air.
Not so much of a problem W/a JN-4 Jenny, but on a P-51, RPM can increase dramaitically in the aor when the airframe is doing 100 MPH & the prop is unloading.
Old 02-05-2013, 03:27 PM
  #24144
FNQFLYER
Not on the P51 I restored / worked on.  Constant speed prop and the wings would fall off before you lunched the engine.  Assuming you weren't stretching the limits  eg war power (which was a number of plus 100% max RPM) or you are racing it with exotic fuels.  Most engine failures on modern engines are due to prop governor problems or just plain structural failure within the engine.Re off load in flight listen to a YS 53 or 63 at max RPM on the ground and then listen for the "upshift" in rpm at about 50feet (or less).  We counted on this in Duration to get that little bit of grunt to get out of ground effect into clean air for the climb.  (The climb was at 87.5 degrees, ideal, for 28 seconds engine run, this usually gave about 1, to 1500 feet.  And for reference the 65 Saito is not far behind on a 32 second engine run)
Note don't confuse prop rpm with actual a/c speed.
Old 02-05-2013, 05:14 PM
  #24145
mike early
mike early's Avatar
ORIGINAL: hsukaria
Yes. I install all my Saitos inverted on all planes.
Old 02-05-2013, 05:29 PM
  #24146
mike early
mike early's Avatar
ORIGINAL: FNQFLYER
Too much math for me to know for sure, but some props unload more at speed than others. I am seeking maximum speed with the overpowered Sundowner 36 and the Saito 82 with the APC 11x12 prop. If nothing breaks, then I'm not pushing it hard enough. Only when something breaks does one know the limitations. No matter what happens, I can fix it....
Old 02-05-2013, 05:41 PM
  #24147
blw
blw's Avatar
The Eagletree measurements I've seen (and those are only a few) bounce around 1000 to 1500 rpm increase in the air. This 'unloading' is the propeller reaching maximum efficiency due to the air being pushed through the prop disk from the airspeed of the aircraft. This is why static rpms on the ground are pretty much meaningless. When the prop starts hitting max efficiency speeds the engine has the load on it reduced, and thus can put out more rpm.
Old 02-05-2013, 06:01 PM
  #24148
FNQFLYER
I would dispute the fact that staic thrust measurements are meaningless.  On 1 : ! a/c staic trust was always the target thrust requirement on engines runs be they piston, gas turbine, (either jet or prop) or rocket engines.
With model a/c type engines you can get the engine to "unload" to varying degrees depending on the design of the prop cuff, blade root design and the general blade design.  Best and most obvious example to us oldies in the Electra L188 / P3C.  Both had the same engine but look at the blade, horses for courses, as similar thing can be seen with the various varients of the C130 / L100 series a/c.
As for all of this, I tune with a tacho, run the engine according to the requirement of the day and have the spares to fix any broken bits.  Makes for a more enjoyable day especially when you come out on top at a competition and you take home the a/c fully assembled still.
Old 02-05-2013, 06:02 PM
  #24149
mike early
mike early's Avatar
I usually prop all my saitos at 9000-9500 static. I've had great success with those numbers but what will happen if a Saito over-revs? valve float? piston-valve contact? Let's see the consequence.
I wish I had a Torque-HP graph on the Saito 82. But even then I would never know the unloaded RPM. Unless I had telemetry. One day I will, but I still need a Torque-HP curve. If club Saito cannot provide that, who can?
Old 02-05-2013, 06:19 PM
  #24150
FNQFLYER
Mike, there is one of those back in the early posts, you can also get that sort of data direct from Saito  I think I also have it on my individual engine sheets that come with the engines
