Welcome to Club SAITO !
Old 08-31-2009, 08:43 PM
  #15801
blw
blw's Avatar
Default RE: Welcome to Club SAITO !
ORIGINAL: ArcticCatRider
What does one do to become a member of Club Saito??
How are the numbers designated??
I've been trying to become part of this exclusive institution for some time now.....what does it take?
I think everyone agrees that you need to own a Saito.
Old 09-01-2009, 06:35 AM
  #15802
ArcticCatRider
ArcticCatRider's Avatar
I own 5 Saitos....
1 .82, 2 .91s, a 1.00 and a 1.20....
Doesn't that qualify as Saito ownership? Or must I own stock in the corporation?
Old 09-01-2009, 03:09 PM
  #15803
japes999
My Feedback: (9)
w8ye,
Thanks for the fast response, you are correct it is just an older FA-120. I don't believe that the idle being set too low is the issue, as when throttling down quickly one doesn't even have to pull back all the way on the stick for the problem to occur. It seems to be more a factor of how quickly the throttle cut rather than how far it is cut. I had one friend suggest that perhaps I am running too rich and that when throttling back rapidly it floods the engine and cools the glow plug and then it kills. That does sound reasonable to me, but wondering if that is the case would I be better off leaning the mid-range disc on my carb, or turning out the low speed (air-bleed) screw? Basically, what would the proper procedure be to rectify my problem?
Old 09-01-2009, 05:31 PM
  #15804
GaGeeBees
My Feedback: (23)
GaGeeBees's Avatar
Sounds like you need to adjust your midrange disc. Try leaning it a bit and see if it improves.
Old 09-02-2009, 09:35 AM
  #15805
blw
blw's Avatar
ArticCatRider- you are member #657
Old 09-02-2009, 10:07 AM
  #15806
mike early
mike early's Avatar
I read someone's item on Ebay claim that the Saito 100 is actually 1.10 cubic inches.
Horizon site also states: Displacement:1.10 cu in (17.10 cc)
But, mathematically: 17.1 cm³ = 1.04350 in³
Obviously Saito knows this, or they'd have called it a 110 and never released the 115.
Old 09-02-2009, 10:24 AM
  #15807
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I think Jim did the nimbers and the 1.00 is really a 1.04, he can correct if I'm wrong, stretching occurs quite often however the MDS 1.48 is actually a 1.52, go figure. I guess MDS loved those numbers ending in 8.
Old 09-03-2009, 08:16 AM
  #15808
ArcticCatRider
Thanks!! Much obliged!!
Now I just need to figure out how to make a sig...
Old 09-03-2009, 10:09 AM
  #15809
blw
blw's Avatar
PM sent regarding sig lines.
Old 09-03-2009, 10:10 AM
  #15810
blw
blw's Avatar
Chancho- you are member #658. Sorry about the delay!
Old 09-03-2009, 10:35 AM
  #15811
Chancho
NP,
Thanks BLW...
Woo Hoo!
Phil
Old 09-04-2009, 07:09 PM
  #15812
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Saito Friends, I did some horse trading in the last couple of days, I sold my Saito TS90 and then found an older NIB Saito 1.00 twin. This one was $449.00 so I got it for the old price. It has a glow plug wrench among the tools. The flex pipes have much larger flutes than the current ones. They will only be on there until I get a couple of more TurboHeaders. The carbs are metered with airbleed trims, the barrels do not move in and out.
ID:	1268701   Click image for larger version
ID:	1268702   Click image for larger version
Old 09-04-2009, 07:49 PM
  #15813
w8ye
My Feedback: (16)
w8ye's Avatar
I have one just like that. I traded out the cam boxes for the current style on mine and put the air pump in the drawer.
Old 09-04-2009, 08:17 PM
  #15814
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Thanks Jim, I noticed that the newest version did not appear to have the pump, but for $150.00 I accepted the pump. Did you just change the right cam box? Thanks
Old 09-04-2009, 09:49 PM
  #15815
mbrennan1
Can anyone tell me the size of the bolt that holds the jug down on an FA 82a? I lost one and need to find a replacement.
Mike
Old 09-04-2009, 10:11 PM
  #15816
cd_webb
While we're researching nut and/or bolt sizes, I have a Saito .30 (with rocker covers). The manuals I've read say that the crankshaft threading is 1/4 28. Dave Brown says it's 6mmX1. Neither fits!! Something as simple as finding the right prop adapter for an aluminum spinner shouldn't be this hard! Does anyone have another (or better) idea as to what I need?
And as long as I'm here, that engine, together with an open rocker .30, two .45's, a 65, an .80, and a 1.00 should qualify for a club member #? Maybe??
Old 09-04-2009, 10:18 PM
  #15817
w8ye
My Feedback: (16)
w8ye's Avatar
ORIGINAL: Hobbsy
I changed both boxes so they would look alike. The current boxes do not have the boss for the air pump
Watch the left cam. you have to use the line instead of the dot.
Old 09-04-2009, 10:23 PM
  #15818
N429EM
N429EM's Avatar
Fellow SAITO enthusiasts,
I have a bit of a dilemma, with my FA-91s. I've tried a couple of different tuning techniques, from this thread. But, I still can't get the top end over about 8800 rpm. I'm using a 14X6 prop, as this is in my 8lb 8oz pattern plane. I had 2 dead stick landings at the last contest, so I removed the VP-20 pump. But, she still won't tune well enough. I have since changed spraybar and HSN. While trying to tune the engine, I can turn the LSN in all the way, at approximately 2500 rpm idle, and it won't stop running. If I try lowering the idle speed it dies.
Also, I have recently readjusted the valve lash to .004mm.
Am I missing a possible air leak somewhere, or what? this is driving me crazy(er).
Thanks, gang,
EJ
Old 09-04-2009, 10:52 PM
  #15819
w8ye
My Feedback: (16)
w8ye's Avatar
There may be something wrong with your LSN
Did you get the notch in the spray bar towards the intake manifold?
Old 09-04-2009, 11:10 PM
  #15820
N429EM
N429EM's Avatar
Yep. In fact, I just double checked.
You know , if you stop and think about it, calling the Low Speed adjustment a needle is incorrect. It's actually a tube that extends over the "notch" in the spraybar. What could possibly go wrong with the LSN? There is nothing that rubs against anything there.
Old 09-04-2009, 11:26 PM
  #15821
w8ye
My Feedback: (16)
w8ye's Avatar
If your spray bar is too small or the low speed tube too large you will get the results you are experiencing
Old 09-05-2009, 07:20 AM
  #15822
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Thanks Jim, I'll cypher om whether its worth it or not to change them.
CD, I have a couple of the little .30s, I'll check them out in a while with my Screw Chek'r, that's really the way they spell it.
Old 09-05-2009, 08:12 AM
  #15823
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
CD, it is 7x1, the little prop nut should be available from Horizon, it came with the GK. The cylinder on my older one is black because I loaned it to Wuilliam Robison for his "Saito Notes" above. He made the cylinder black as a little joke. It's a special treasure now. One other specail treasure is an ASP 1.08 RedHead, a gift from w8ye.
CD, the Saito parts designation for the .30 is MM, here is alink to the prop nut.
http://www.horizonhobby.com/Products...rodID=SAI30S30
ID:	1268904   Click image for larger version
ID:	1268905   Click image for larger version
Old 09-05-2009, 08:38 AM
  #15824
cd_webb
Hobbsy, thanks a bunch! Only other thing is where did you find a gadget like a Screw Chek'r? I'm pretty sure that would be a nice thing to have around.
Old 09-05-2009, 09:06 AM
  #15825
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Right here, http://www.micromark.com/METRIC-SCREW-CHEKR,7043.html
