Welcome to Club SAITO !
Old 04-27-2008, 01:34 PM
  #10726
linkadrip
linkadrip's Avatar
Default RE: Welcome to Club SAITO !
Great thanks appriciate it. Nice looking corsair there. [sm=thumbup.gif]
Old 04-27-2008, 04:16 PM
  #10727
blw
blw's Avatar
ORIGINAL: mbrennan1
I bought a GP Venus to replace this Lark 70. I liked the way the Lark flew. but it was not the easiest plane to build.
Club Saito Member #591
Hmmmm, looks repairable maybe with a new nose section. I wouldn't toss it yet.
Old 04-27-2008, 05:03 PM
  #10728
mbrennan1
I saved it. Maybe some rainy day I will start rebuilding it.
Old 04-27-2008, 08:36 PM
  #10729
Wingspam
I have a Saito 180 and I keep having problems with the muffler coming loose at the muffler. I have tried blue lock tight and red. The red held longer but still came loose. I have rechecked the prop for balance and it is good.
Being tired of the stock muffler, where can I get a good after market muffler?
Do they make a 1 piece muffler for the 180?
Thanks in advance
Old 04-27-2008, 08:48 PM
  #10730
Kmot
My Feedback: (24)
Kmot's Avatar
Is there a way to upload a PDF file onto the forum? I have something useful for Club Saito if there is a way.
Old 04-27-2008, 10:02 PM
  #10731
clutchbob
I have just recently aquired my first 4 stroke - a Saito 72. I'm very pleased with this engine. It idles very slowly and transitions to WOT without a hiccup, and it's just barely broken in.
Have you tried tightening while the engine is hot?
Old 04-27-2008, 10:11 PM
  #10732
rexracer
Kmot, can't you just click on the link at the bottom of the message window like you do to upload pics?
Old 04-27-2008, 11:27 PM
  #10733
Kmot
My Feedback: (24)
Kmot's Avatar
No, that dialog box does not support PDF.
Old 04-27-2008, 11:59 PM
  #10734
s10junky83
I'm having a horrible time setting my ls needle on a saito 100. My HS needle is peeked at 9000 on 30% coolpower and my LS has a very small "sweet spot" that is within 1/4 of a turn. Problem is if I lean it, it idles way to high then dies. If I richen it, it will run then die within a minute. It always starts immeadiatly after dying. Could the valves be too loose? If I put them on the feeler gauge the motor vibrates horribly. I need to add that this motor ran and idled great when it was sloppy rich but only peaked at 8100 rpm and that won't hover my 7 LBS plane. Please tell me what to do!!!!!!!!!!!!
Old 04-28-2008, 01:07 AM
  #10735
swixtt
swixtt's Avatar
hey guys,
can someone post how they start their Saito 150's or 180's... i seem to always kick my prop nut(a dubro one). it is on a test stand... i prime with just one turn of the prop(manually) then either stick-it or use the starter. when i do prime it i believe it just draws too much fuel in the cylinder there by causing the kick-back when i go to start it.
Old 04-28-2008, 08:37 AM
  #10736
w8ye
My Feedback: (16)
w8ye's Avatar
I stick the electric starter to the engine and it starts.
Are you trying to start your engine by hand?
Old 04-28-2008, 08:43 AM
  #10737
blw
blw's Avatar
ORIGINAL: s10junky83
This page has a good explanation of setting your valves correctly: http://www.saito-engines.info/maintenance.html. Remember, the feeler gauge is a 'feeler'. You should be feeling the gauge fitting slightly when the valves are just right.
Yes, the low speed needle valve is sensitive when you are near the right place. 1/4 turns are huge adjustments. Look for 1/8 adjustments, or even less. When I get close to where it should be, I don't shove the throttle to wide open at first. I ease it up and listen. If the engine is taking the throttle well, I then start advancing it faster until I know it isn't too lean. BTW, I set the LS with the HS set to peak RPMs. When finished with the LS, I then repeak the HS and back off a few hundred RPMs. I back off more if the engine is under a gallon of fuel thru it. Then, most importantly, I take the model up for a trip around the pattern as I listen closely to the engine. Any sign of sagging, surging, or roughness means I land and richen the HS a couple of clicks, and do another pattern until it is running smoothly.
Old 04-28-2008, 08:45 AM
  #10738
swixtt
swixtt's Avatar
ORIGINAL: w8ye
both ways.
Old 04-28-2008, 09:16 AM
  #10739
w8ye
My Feedback: (16)
w8ye's Avatar
It takes a strong starter to start a 150 or 180. With a regular starter the engine will just oscillate between top dead center from one direction to the other without ever going past top dead center.
The people who hand start generally bounce them against top dead center from the reverse direction whereby the engine more or less back fires and starts running in the forward direction.
Old 04-28-2008, 09:43 AM
  #10740
1rcaddict
The Sullivan Dynatron works perfect on my 180 with no priming at all.
Old 04-28-2008, 10:17 AM
  #10741
swixtt
swixtt's Avatar
ORIGINAL: 1rcaddict
what does that starter draw? what type of bat. do you guys use for a larger starter? i believe that is probably part of the issue, possibly??
Old 04-28-2008, 10:44 AM
  #10742
1rcaddict
I'm not sure what the draw is but the 7000mah Hobbico gel cell from Tower Hobbies works great. I think there only about $20.00.
Old 04-28-2008, 11:15 AM
  #10743
rexracer
I have a hobbico 1.80 starter that didn't like to spin my 1.80, so now I'm running it at 24vDC and it spins it easily. I was worried about burning it out, but one guy in our club has been doing this for 5 years on his hobbico starter without a problem.
Old 04-28-2008, 11:57 AM
  #10744
Walther
Just remember a DC motor draws more amps on 12v then on 24v 2X so if it draws 10 on 12v it draws 5 on 24v.
Old 04-28-2008, 12:31 PM
  #10745
clutchbob
Are you sure about this? The motor windings present themselves as a resistance (load), this doesnt change when applied voltages are changed. If the voltage is doubled across the same load, current is going to double as well. Voltage = Current (in amps) X Resistance (in ohms).
Old 04-28-2008, 12:35 PM
  #10746
swixtt
swixtt's Avatar
thanks for the info. i do have a hi-torque starter but it is OLD. so i have no idea what it's rated at. but i won't spin the 1.50 over very easily and does what w8 said... bouncing but not turning it over.
if you guys are using a Dubro Prop nut do you have the washer in there as well? or removed?
Old 04-28-2008, 12:40 PM
  #10747
clutchbob
Try a battery that can supply more instantaneous current like a car battery.
Old 04-28-2008, 12:46 PM
  #10748
swixtt
swixtt's Avatar
ORIGINAL: clutchbob
yeah,i've got a rather large one from a UPS and i've tried one that is used to jump starting cars. it's a handy unit that is VERY portable. got it from Canadian Tire!!
Old 04-28-2008, 02:11 PM
  #10749
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
This is true, DC motors don't develope any Counter EMF like AC motors, so they just take whatever you throw at em. They look like a dead short to the battery.
Old 04-28-2008, 02:49 PM
  #10750
TomCrump
TomCrump's Avatar
ORIGINAL: w8ye
Regarding the dimension of the 325 from the back of the prop to the cylinder . . .
From looking at the Saito 325 manual in the link above, it gives a dimension of 100 mm from the prop flange to the C/L of the cylinder.
I measure 27mm from the C/L of the cylinder to the front of the valve cover. Therefore the dimension you are looking for is
73mm
Thanks !!!! I really appreciate it.
Now, I'm off to measure my cowl.
