Welcome to Club SAITO !
Old 12-21-2019, 01:57 PM
  #44376
Glowgeek
Nicely done tree, I usually flock mine up trying to decorate it.
I like the cork carving. I have a large one like that too.
Old 12-21-2019, 02:06 PM
  #44377
1200SportsterRider
1200SportsterRider's Avatar
Thankyou Lonnie
Old 12-21-2019, 03:09 PM
  #44378
Glowgeek
I got a good chuckle out of that guy over on rcg classies wanting to buy Gary's brass display stands instead of the Saito. Lol
Old 12-21-2019, 05:38 PM
  #44379
Jesse Open
Jesse Open's Avatar
He wound up buying the Saito to get the stands!
BTW, Castor oil is an excellent assembly lube, provided you run the engine within a few months. Actually darn near the best in that case.
Old 12-21-2019, 05:41 PM
  #44380
Glowgeek
Well, they are pretty sweet stands.
Old 12-21-2019, 06:14 PM
  #44381
Glowgeek
Gary, to convert your fg20 to run it on glow was it just a carb swap from an fa125? The fg20 intake works or not?
Old 12-21-2019, 07:04 PM
  #44382
the Wasp
I would make those stands, polish them and sell them but that's a lot of time and materiel waste
Jim
Old 12-22-2019, 04:46 AM
  #44383
Jesse Open
Jesse Open's Avatar
Lonnie,
I trashed the Saito ignition and used an RCexl in its place. Also used the CH trigger mount which is a huge improvement and works with the factory mounting holes. Sure beats tie wraps that some folks insist on.
The Saito has carb was stripped of a few useful parts like the throttle arm and fuel inlet nipple, whacked with a hammer and dumped in the trash can.
The stinkoline carb uses four flanged plastic bushings and smaller diameter screws for mounting. Those bushings and screws were transferred to the methanol carb.
You could easily tap out the holes to use standard screws and, most likely a shim the same thickness as the bushing flanges to keep the right position.
The intake pipe (everybody calls it a manifold, but it isn't ) was used. I did not compare part numbers but the pipes may be the same, they are at least very similar.
Heat insulation bushings
Old 12-22-2019, 05:07 AM
  #44384
Glowgeek
Thanks. Which rcexl module did you use? The older one that required a static timing of 40° btdc or one of the newer ones that get timed at 28-30° btdc? Just curious if that CH bracket has enough adjustment to compensate for the 40° btdc magnet position on Saitos when using using ignitions set up for 28-30°.
Old 12-22-2019, 05:16 AM
  #44385
Glowgeek
Found this image on an FG20/21 thread. The pin hole in the carb body next to the high speed needle indicates that this carb is the updated version for the FG20. The FG21 uses the same carb. Very few people had any luck getting their FG20's to run right with the older carb but most have no problems with this updated version. Sorry if this has already been covered on this monster thread.
Old 12-22-2019, 06:13 AM
  #44386
Glowgeek
Default Saito FG21 transition problem
For those running saitos gassers, do you have ongoing problems when quickly transitioning from idle to wot? Mine gasps and quits. No backfire, just gasps like there's not enough fuel for transition. Richening the lsn just leads to an idle which continuously drops rpm until the engine quits. Leaning the lsn leads to idle increasing rpm until the engine quits. Where I have the lsn set right now it will idle at 1950 rpm +/- 25 rpm all day and as long as I don't transition to wot too fast it transitions fine. Runs fairly smooth at all throttle settings too.
Anyway, is this normal behavior until the engine breaks in further? Will the problem eventually go away? I've run almost 1/2 gl of fuel through it so far and have tried static timing settings ranging from approx 27°-34° btdc using the Rcexl V02 cdi. No joy so far.
prop is a xoar 15x8
fuel is 89 octane 20% stihl ultra hp,
temp 50°f
battery is a LiFe 6.6v
peak rpm 8200
compression is excellent
no valve leaks
valve lash set to .002"
Old 12-22-2019, 06:47 AM
  #44387
Charley38
I used to be Charley on RCU but now I can't log in under that name and the "forgot password" function doesn't send me an Email. I had to reregister as Charley38 using my Gmail account because RCU won't let me use my twc account; tells me it's already taken. Sent admin a query yesterday but no reply. Don't know what to do in order to get my original account working again....
Old 12-22-2019, 07:55 AM
  #44388
acdii
prop is a xoar 15x8
temp 50°f
peak rpm 8200
no valve leaks
Nope, all mine run fine, FG-11 and FG-30. All run on factory settings. I use 93 octane no ethanol fuel with Amsoil oil.
Old 12-22-2019, 02:08 PM
  #44389
1200SportsterRider
Charley, that is being worked on as we speak, I too am unable to use my original Log In.
Old 12-22-2019, 03:41 PM
  #44390
Glowgeek
I hope Pete is OK, record breaking temps down under. 107°f nationwide average temp and in some places temps of 122°f were recorded. That's smokin' hot, literally; they have a over a hundred wild fires going on right now.
Oh what am I worried about, he's probably sprawled out in a swimming pool full of ice and beer right now.
Old 12-22-2019, 06:22 PM
  #44391
the Wasp
prop is a xoar 15x8
temp 50°f
peak rpm 8200
no valve leaks
Lommie, try adjusting your plug gap a bit, go up or down about .002 to .003" at a time. I say this because the Z G20E with the RcX E-box produced the best mid range power in our Helis with a plug gap around .018 to.019 (the Century Radical 20 Gasser)
edit, yes I understand the Z G20 is a big ol smelly 2 St that use's a different plug, never the less please just try a different gap
Jim
Old 12-22-2019, 06:24 PM
  #44392
Glowgeek
Thanks Jim, I'll try that.
Old 12-22-2019, 06:30 PM
  #44393
the Wasp
naa, not Pete, he's out-there doing a 120MPH around some corner on his bike with the wind in his face
Jim
Old 12-22-2019, 06:35 PM
  #44394
the Wasp
hey, it's worth a try
BTW, I edited my post above
Jim
Old 12-22-2019, 06:50 PM
  #44395
the Wasp
hey, if I don't sign on tomorrow I sure hope that all of my Saito Freak friends here have a vary good evening tomorrow and even a better Xmas day, I hope you all get to spend the best time with those you love most !!!
I'm a bit sad because I wont see my daughter and 2 grand daughters, but I wont let that show. my son and daughter in-law will come for supper tomorrow and on Xmas day all four of us will be going out for supper, be safe my friends !!!
Jim Bob yee Saito freak
a tidbit of life: it's a most believed fact that cultivation came forth for the most beloved reason>,,,, "Beer"
Old 12-22-2019, 06:59 PM
  #44396
Glowgeek
Yes, Season's Greetings and best wishes to everyone here.
ps: Jim, I don't drink so have a beer for me, just remember to leave those keys on the counter!
Old 12-23-2019, 05:05 AM
  #44397
1200SportsterRider
Pete is just fine, I received an E-Mail from him a couple of days ago, somehow the new software can't send us a new password if we have forgotten our old one. It'll be fixed in a day or two.
Happy Holidays to all the Saito Buds.
Old 12-23-2019, 05:56 AM
  #44398
FlyerInOKC
FlyerInOKC's Avatar
Being down under I figured he was just busy drinking his share of Christmas cheer!
Old 12-23-2019, 07:47 AM
  #44399
acdii
Just think, on the other side of the planet, someone at some point is standing in the exact same spot as you are.
Old 12-23-2019, 08:09 AM
  #44400
FlyerInOKC
FlyerInOKC's Avatar
I wish there was a website you could plug an address into and it would show you what the exact spot on the other side of the world would look like. With my luck its either desert or open ocean.
