What’s coming 2020?
Thank you Bob. The first one i am finishing is 90mm EDF with 8 cell Schubeler fan. It is almost done so your information is just on time. I was looking at the back fins last night. Are yours holding up? I wish they were made of G10 or something like that.
Behzad
Behzad
They don't really extend beyond the bottom of the fuse so they should hold up. I taped them into position and glued the pin from the inside then ran a small fillet of glue along the fuse joint from inner side, worked well.
Behzad,
Iwould take a look at the way the gear mounts are attached to the spars in the wing. The spars are very fragile whilst the gear monts are much stronger. I had a K30 in my MB339 that was garbage and it kept stopping. A heavy landing ensued that broke my wing spars whilst leaving the mounting plates intact. These are hard to repair so I suggest that you beef them up now. I aslo found that the wheels and struts where not up to much so Got some jet 1A legs and Robart wheels. Nice model with the X45. No need for flap on take off with this engine and only half flap on landing. Also bring it in with a tickle of throttle as the rsidual thrust is so slow it can slow down too much.
John
John
behzad
#31
https://www.ebay.com/i/223608798052?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=223608798052&targetid=475515098301&device=c&mktype=pla&googleloc=9033270&poi=&campaignid=6469750693&mkgroupid=79220282802&rlsatarget=aud-412677883135la-475515098301&abcId=1141176&merchantid=115027242&gclid=CjwKCAiArJjvBRACEiwA-Wiqqzk4Z0EoTHPGAyK30ZN3szhqqRRkfU9jETJorY5KmjTQ8Zj u9iX_6hoCeaIQAvD_BwE
#33
#35
Interesting, orginal was 11 mtrs so that comes out at 1/3.37 which is strange?
Bit bigger than the Tomahawk version.
Many thanks,
Many thanks,
#36
Figured I would just update. BVM F15, BVM F100, SM F86, Carf Bolt. And T one bringing out a F35 and cougar and I’m sure plenty more unannounced stuff from other manufacturers
some Nice stuff coming out this year!
