T-28 Dave Platt
#376
RE: T-28 Dave Platt
Boyd,
Sorry to hear about the lack of flying. Weather here is dampening the flying time we may have left this season.
Will post some pix tonight on the Trojan, and I ave a flap question that you might be able to anser after you see the pix....
Deans plane is certainly an inspiration...
On a happier note the Avneger kicked to life yesterday next step is to go over everything and make sure it's tight as well a s a few finishing touches and then if the weather cooperates maybe a test flight before the year is over (doubtful as the winds at the beach have been a steady 15-20 with gusts avg around 25 - 30 mph.
Now that the flaps are started I'm getting antsy to get past that part and start on the ailerons. Will het the flap hinges drilled tonight and test fit into the wing and flaps.
Just in case, I hope everyone has a great Thanksgiving and the weather coooperates so you guys can continue flying, Dean doesn't have to worry, he has perfect weather year round
Larry
Larry
#377
RE: T-28 Dave Platt
ORIGINAL: maser
Dean,
Beautiful work. What is the power plant you are using? How did you get the canopy to slide back in the angled position like the real one?
Boyd
Dean,
Boyd
#379
My Feedback: (20)
RE: T-28 Dave Platt
To Dean RCU,
Nice T-28 you got there.
You mentioned you were waiting for scale wheels from Glennis. Have you heard anything from them? I am also waiting
for my scale wheels.... 7 months now.... I've been emailing and calling with no response
Thanks, Dave
Thanks, Dave
#380
RE: T-28 Dave Platt
hey guys,
here are a couple of shots of the flaps, will drill out hangers tonight and hopefully test fit by turkey day. I have to mount the flap servos but am waiting to see how the flaps mount before I mount them wrong.
Any hints?
Boyd, are you going to go gas or glow, I can't decide....
Larry
Any hints?
Larry
#381
RE: T-28 Dave Platt
ORIGINAL: DaveZ
To Dean RCU,
Thanks, Dave
To Dean RCU,
Thanks, Dave
I ordered them about six weeks ago. I hope it don't take that long I'm so old that I don't even buy green bananas anymore. I've purchased wheels from him four times before for other models and the longest wait time was about two months. I know that he is dealing with a father who has health problems.
Dean
#382
OK
RE: T-28 Dave Platt
Larry,
I went with gas. A Fuji 50. If you start at page 7 it will show you how I did mine. I had to extend the mount for the engine forward because the cylinder would hit the nose gear unit.
Good luck.
Boyd.
Good luck.
Boyd.
#383
RE: T-28 Dave Platt
Boyd,
I have a problem with the site for the fuse build, the pix don't show up and they won't load...
Will hopefully be ready to test fit the flaps tonight, will post pix as soon as I have them fitted
Larry
Larry
#385
RE: T-28 Dave Platt
Boyd,
Thanks for the pix. Have all the cutouts done in the flaps for the hangers and the hangers are all drilled out.
Getting ready to start sanding the LE of the flaps.
Nice day at the field yesterday too bad I could only do 2 hours there
Hope uyou guys get some good flying weather this weekend
Larry
Larry
#386
RE: T-28 Dave Platt
Hey guys,
Hope you've had some great flying weather...
Just started gluing the flap hangers into the flaps, hoping to have that done bu tomorrow evening..
Too much drama going on here to get any serious modeling in not to mention that my brain is fried after 10-1/2 hour work days...
Will post pix as soon as I get the hangers glued...
Larry
Larry
#387
RE: T-28 Dave Platt
Hey guys,
Stupid question of the day. Am I better off installing the ailerons first and then installing the flaps to match the angles or vice versa?
Larry
Larry
#388
RE: T-28 Dave Platt
ORIGINAL: lkahn4
Hey guys,
Larry
Hey guys,
Larry
#389
RE: T-28 Dave Platt
Hey Boyd,
Started on the ailerons, very intriguing way to get access to the aileron rod... I'm thinking of a doing the same thing but attaching mini magnets to each rib thus not having any screws showing.. my question is did you use 1/8" or 1/4" plywood for the inboard ribs?
Things are going into hibernation for awhile, turns out I'm moving into my mother inlaws condo so I have to start packing for the move and clean out her condo at the same time... not too happy about it but the wife isn't giving me an option..
Will try and post some pix this weekend
Larry
Larry
#390
OK
RE: T-28 Dave Platt
Larry,
I used 1/4 ply on the inbordrib. I canit take if off by a couple of screws, thus being able to get therod out that holds the aileron to the wing.
Good luck on the move.
MerryChristmas to all.
Boyd.
Boyd.
#391
RE: T-28 Dave Platt
Hi guys,
Hope you guys had a very Merry and fruit full Xmas.
In the middle of cleaning out my mother in laws condo for the move and work I have managed to get some build time in.
Here are a couple of pix of the ailerons and test fitting of the flaps, have to get a piece of G-10 to redo one of the flap hangers, cut it way too short for the one that attaches by the gear on the left hand one.
Trying to get the wing done before the move but it's not looking good..
Snow and wind has kept most of us from the field even though the weather was in the 40's up until last Thursday.
Larry
Larry
#393
RE: T-28 Dave Platt
Hey guys,
Finally back to the bird. Got the flap servos setup and getting ready to epoxy in the flap hangers finally. Ordered the aileron servos today and hopefully will be ready to sheet the wing by the end of the month.
Did either of you put lights in the wingtips, if so what did you use?
Weather here has been cold and windy, hopefully will get warmer by the end of the month.
On a happier note we will finally fly the Avenger on April 27th and hopefully get it back on the ground in 1 piece.
I will have some more ?'s once I get ready to start sheeting.
Thanks guys for all your tutelage and guidance, I really appreciate it
Larry
Larry
#394
RE: T-28 Dave Platt
Hi Larry, I used http://electrodynam.com/store/SunVis.html
Hope to have some imsges of my T-28D with all the markings soon.
Dean
Dean
#395
RE: T-28 Dave Platt
Hey Dean
Thanks for the info. When you take the next set of pix can you take a shot of the wing tip showing the nav lights.
Thanks again for the info.
Larry
Larry
#396
OK
RE: T-28 Dave Platt
Dean,
Where do you come up with these items. You keep amazing me with all these neat things.
Larry,
I did not put any lighting system in mine.
BTW, I still have not had good weather to complete the primer/paint job.
Boyd.
Larry,
Boyd.
#397
OK
RE: T-28 Dave Platt
Larry,
Good luck on the Avenger flight. I keep looking at the Kellogg thread. Peter does an amazing job on his. He andDean could win some nice trophies.
Boyd
Boyd
#399
RE: T-28 Dave Platt
Hi Boyd, Give me a few days to get all the assemblies togther and get my daughter to help me set the model up so she can add it to the Web site she has developed for my models.
Dean
http://kleekai.wix.com/deanmonticelli
Dean
#400
RE: T-28 Dave Platt
Dean,
I have to say that not only is your build acumen subject to none but what an awesome website, you and Peter should get together.
Have a question for you guys, one of the guys at the field gave me a slightly used Super Tigre S-2000 engine and I was wondering if you think it will be powerful enough for the Trojan, according to Daves drawing he used a 2500 the super tigre website doesn't list the specs for it but the G2300 is 1.42 CU and 3.7hp.
Weather here is still a bit windy with winds running between 10 and 20 with gusts over 25mph.
Larry
Larry
