Aviation Design Mini Diamond
#126
Salve,
I´ve bought a Mini at JetPower Fair.
The recomended servos of AD are not realy my choise.
I make new servo-covers of CFK and install KST X10 Mini.
Turbine will be a Jets Munt Merlin 100.
Waiting for some parts for the landing gear and then the Mini is ready for maiden.
Is it realy true, that the elevator ist 4mm up at neutral trim?
If yes, then there is something wrong with the angle between wing and stab !
The manual of the Big Diamond dont describes an uptrim.
Regards
Thomas
Regards
Thomas
#127
Salve,
Regards
Thomas
Regards
Thomas
mL
#128
I took the plunge and upgraded to a 147N (34lbs) Jet Central Cheetah SP. I must say I like it!! With the JetsMunt Merlin 100xbl my top speed was in the 160's, know lets just say I'm around 199.7 mph. Everything fit great and no extra lead needed to balance (removed lead needed for the 100 and a 2S 2200mah lipo and added the 3S Life 3800 for the Cheetah) at about 27.6 lbs AUW with 34 lbs or thrust. Also want to thank one of our GA Jets Club members Desert Fox 1(youtube: Rmshump) for taking such great videos and doing such a great job of editing!!! Enjoy!!
#131
Salve,
ready for maiden. If the weather is OK I will do it tomorrow or an Thursday.
dry weight is 9,25Kg (20,4lbs) + 2,5L fuel in a Platypus = 11,35Kg TOW (25lbs)
I think it is easy going for the Merlin 100.
Did you use a little bit flaps down for the take of?
Have you changed the settings of the manual after the first flights, or they are OK?
The expo settings are low (elevator only 10%) is this OK, or is the plane to nervously with this?
Regards
Thomas
Regards
Thomas
#132
Salve,
Regards
Thomas
Regards
Thomas
ML
#133
Salve,
maiden is done.
Fly´s like on rails, but not so fast I hoped.
I remove the 4mm up trim of elevator to 2mm up trim to fly in level.
All settings from the manual are right, nothing to change.
Great plane.
Thank you for your informations ML.
Regards
Thomas
maiden is done.
Great plane.
Regards
Thomas
#134
ML
#136
the SE (newest version) is 160 while the power pack SP (previous version) is 147N.
#138
Hello
nice flight.
I installed in my diamond a B140F turbine now.
And I have installed a geardoor for the nose gear.
Speed is with 130.000 RPM of turbine is 390 km/h
I will tune up the Turbine to 132.000I hope the diamond will goes up to 400 km/h.
have fun with your diamonds guys .
regards
Thomas
nice flight.
regards
Thomas
#139
I wanted to share that I recently purchased the larger tank from CMJ. The stock tank is 2.5L and this one is 3.2L. This should allow me to take advantage of my cheetah without the sub 5 min flight times!
#141
Just wondering, are you dealing with a local shop or Aviation Design directly? I dealt with Corinne Rantet at Aviation design and she was always johnny on the spot and made my overseas purchase painless!
#142
I just measured the actual fuel gain and I was a little disappointed! With the stock tank, it's advertised as a 2.5L and it had 2.1L usable. This tank is advertised as a 3.2L it has 2.4L usable. FYI, these numbers come from using a 2 liter graduated cylinder and pumping out the usable fuel (this is done on all of my planes to calibrate my fuel telemetry).
#146
Hello
B140F (145N thrust)
2,5L fuel in a Platypus-bag, real airtime 6 minutes.
Fuel at the end is enough for 1 turn around.
Flying style "fast"
I installed a gear door for the nosegear. it will make the diamond a little bit faster (400km/h) and more quiet.
Regards
Thomas
B140F (145N thrust)
Flying style "fast"
Regards
Thomas
#147
My Feedback: (41)
FL
Aviation Design Mini-Diamond For Sale...
Anyone here looking for this model--- here is the link I have a flawless one for sale...
https://www.rcgroups.com/forums/show...n-Mini-Diamond
