Reload this Page >
Aviation Design Mini Diamond
Old 03-17-2017, 09:03 AM
  #76
LA jetguy
LA jetguy's Avatar
Originally Posted by scoeroo
I see you did some thrust pipe mods - upgraded
For what reasons ? was the original too flimsy ?
Thx.
The original from manufacture was of good quality but designed for a 100 size turbine. Since we decided to go with 140 size turbines we custom ordered pipes from Tam...
David
Old 03-17-2017, 10:41 AM
  #77
scoeroo
My Feedback: (9)
scoeroo's Avatar
Would you mind PM me the info / differences
Thx Grant
Old 03-18-2017, 10:07 PM
  #78
DrV
DrV's Avatar
More pics of my White Carbon Diamond
ID:	2206054   Click image for larger version
ID:	2206055   Click image for larger version
ID:	2206056   Click image for larger version
ID:	2206057   Click image for larger version
ID:	2206058   Click image for larger version
ID:	2206059   Click image for larger version
ID:	2206060   Click image for larger version
ID:	2206062   Click image for larger version
ID:	2206063   Click image for larger version
ID:	2206064   Click image for larger version
ID:	2206065   Click image for larger version
ID:	2206066   Click image for larger version
ID:	2206067   Click image for larger version
ID:	2206068   Click image for larger version
Old 03-18-2017, 10:08 PM
  #79
DrV
DrV's Avatar
I would like to thank Ken Simmons for the great shots.
Old 03-19-2017, 02:24 AM
  #80
Johnny9390
My Feedback: (34)
https://www.facebook.com/lior.zahavi...70204283030970
Old 03-19-2017, 02:25 AM
  #81
Johnny9390
My Feedback: (34)
It's FAST!! This is blowing a ULtra Flash away in speed! Both with ATJ 140's
Old 03-19-2017, 06:26 AM
  #82
scoeroo
My Feedback: (9)
scoeroo's Avatar
Niiiiice x 2
Old 03-19-2017, 08:32 AM
  #83
LA jetguy
LA jetguy's Avatar
Here are my pictures...
Thank you Kenny for these shots...
David
ID:	2206139   Click image for larger version
ID:	2206140   Click image for larger version
ID:	2206141   Click image for larger version
ID:	2206142   Click image for larger version
ID:	2206143   Click image for larger version
Old 03-27-2017, 07:35 AM
  #84
DrV
DrV's Avatar
We got some more flights this past weekend and dialed in the plane a bit more. Here are more pics shot by Ken Simmons
Name:	DIAMOND DAY 3-23-17 006.JPG
ID:	2207276   Click image for larger version
Name:	DIAMOND DAY 3-23-17 010.JPG
ID:	2207277   Click image for larger version
Name:	DIAMOND DAY 3-23-17 011.JPG
ID:	2207278   Click image for larger version
Name:	DIAMOND DAY 3-23-17 015.JPG
ID:	2207279   Click image for larger version
Name:	DIAMOND DAY 3-23-17 031.JPG
ID:	2207280   Click image for larger version
Name:	DIAMOND DAY 3-23-17 033.JPG
ID:	2207281   Click image for larger version
Name:	DIAMOND DAY 3-23-17 037.JPG
ID:	2207282   Click image for larger version
Name:	DIAMOND DAY 3-23-17 039.JPG
Name:	DIAMOND DAY 3-23-17 040.JPG
Old 03-27-2017, 03:03 PM
  #85
scoeroo
My Feedback: (9)
scoeroo's Avatar
That metallic red diamond jet looks neat - think i'll have a couple of beers tonite and ponder the purchase of one
Old 04-02-2017, 10:04 PM
  #86
omaryafi
Hello,
i have the same jet with the exact landing gear, do you mind sharing the figures on the Xicoy CG and in particular the distance between Main and CG.
thanks.
Omar
Old 04-02-2017, 10:05 PM
  #87
omaryafi
Originally Posted by leemkl06
Well the Diamond has the retracts installed! Still need to complete my wiring harness but it was nice seeing her standing on her own. I must say that I'm impressed with how accurate AD was with with the CG. With their recommended turbine (Merlin 100 XBL and 500g of lipos up front, it perfectly hit the recommended CG (done with my Xicoy CG machine). Again these are preliminary numbers but she comes in at 22.6 lbs with an empty main and full UAT.
Hello,
thanks.
Omar
Old 04-03-2017, 05:19 AM
  #88
leemkl06
Originally Posted by omaryafi
Hello,
thanks.
Omar
Omar, I really discourage pilots from using other builders measurements outright. Your actual measurements are key to your CG being calculated correctly. No two builders build the same (even with the same components). Hopefully your using these for reference to compare with your own and with that in mind here they are.
Front - Main = 711 mm
Mains - CG = 34 mm
Happy Flying!!!!!
Old 04-04-2017, 11:08 PM
  #89
omaryafi
Thank you for the information and the figures, absolutely the figures will be for reference, my CG for first flight was at 52 mm Main-CG which was tooooo nose heavy, now i put it back to 38 mm and will test it this weekend if its up to my liking. i like to fly a bit nose heavy planes.
thank you for the support again.
Cheers!
Mains - CG = 34 mm
Happy Flying!!!!!
Old 04-05-2017, 10:01 PM
  #90
omaryafi
Hello,
I have a question about the flap position for normal flying, when the flaps are up, are they meant to be higher than the ailerons or on the same level? mine is higher than the airleron by like 3 mm if they are fully up, is that the correct setup or i need to get them leveled to the Ailerons.
thanks for the reply.
Old 04-05-2017, 10:15 PM
  #91
DrV
DrV's Avatar
Hello,
On my plane they are higher then the ailerons but on my friend's plane (Red color)they are same level. They both fly the same way.
Old 04-05-2017, 10:48 PM
  #92
omaryafi
thank you so much for the quick reply. I appreciate it.
regards,
Old 05-13-2017, 04:27 PM
  #93
leemkl06
Just wanted to share that I also finally maiden my gold mini today! Our weather hasn't been cooperating but today was the day. I must say that I'm really pleased with the jet and comments that it flies like a trainer is correct (that is a very fast trainer). As shown in the previous pics, mine has an Igyro SRS and it flew like it was on rails. The only issue I ran into was while I was trimming her on the maiden, I deployed full flaps at too high of a speed and both servos burnt out (100% my fault). I will replace them with some of our higher torque options. If your on the fence, do yourself a favor and pull the trigger!
Happy flyin!
Old 05-13-2017, 06:32 PM
  #94
Desert Fox 1
leemkl06,
Congrats on a successful maiden! Looking forward to a video or two with you at the controls.
Cheers!
Desert Fox 1
Old 05-14-2017, 09:12 AM
  #95
leemkl06
Originally Posted by Desert Fox 1
leemkl06,
Cheers!
Desert Fox 1
Thx Desert Fox! As normal for me, I attempted to record the maiden but my GoPro was set to picture mode instead of video. On my next outing, I'm planning to record some video to share.
ML
Old 05-14-2017, 09:45 AM
  #96
Bob_B
Bob_B's Avatar
Happy flyin!
Congrats! Maiden LMAC?
Old 05-14-2017, 01:56 PM
  #97
leemkl06
Yep, it was beautiful day at LMAC! In fact, we had about 4 maidens that day. HSD Turbo Foam Super Viper, Mini Diamond, a large Scale Stearman and a Freewing F5 Tiger. Great Day of Flying!
ML
Old 05-29-2017, 04:59 PM
  #98
leemkl06
Today was flight #4 and she's really getting dialed in! This is a great plane to fly and has a great feel in the air! Enjoy the quick vid!
Old 05-31-2017, 03:30 AM
  #99
mcr01
Hello guys,
at first sorry for my bad English.
I can not find informations about the Mini in German forumīs.
Iīm interested at the Mini and think about to install a B140F turbine to go fast.
Maybe there will be a problem of the higher TOW as with a Merlin 100, because our airfield have only 120m length.
I calculate nearly 1Kg more at take of (little more fuel) and 0,4Kg more at landing with the BF instad of the Merlin 100X-BL.
The take of will be not the problem ;-)
Is the plane stable enough with a 140N turbine to go full power.?
Is it possible to fly (land) at 120m?
@ leemkl06: I see the nice slow and short landing in your video, What is the weight of your Mini?
Regards from Germany
Thomas
Old 05-31-2017, 04:21 AM
  #100
leemkl06
Originally Posted by mcr01
Hello guys,
Thomas
23.10lbs (10.48kg) dry and 26.56 lbs (12.05kg) wet.
Also, all of the videos I've seen with a 140 has been very impressive! (have a look at post #80)
ML
