Reload this Page >
Skygate C-ARF L39 build thread and virtual manual
Old 11-15-2019, 04:48 AM
  #151
Dave Wilshere
I wanted the seats to be removable and also to have something to aid holding the pilots in so I have let in 4 brass inserts to the foam spacers which are glued to the floor. The seat foam spacers were glued to the floor. I also decided it would be cleaner to have the floor mounted centre consoles removal. I used magnets here, letting the inserts into the floor. The rear has two magnets and the front one as the nose unit acts as an anti rotation stop! I've added Velcro to the sides, so its just the pilots and control columns to mount.
Old 11-16-2019, 04:54 AM
  #152
Bob_B
Bob_B's Avatar
Dave could you post a photo of the instrument panel hoods from side and top.
i need the shape if both as I’m building a cockpit for a smaller L39 that came without and has nothing available
Old 11-16-2019, 07:00 AM
  #153
Dave Wilshere
Bob
The owner collected it yesterday pm. Will see if I did any shots from those angles
Dave
Old 11-16-2019, 08:40 AM
  #154
Bob_B
Bob_B's Avatar
No worries, i’ve got a pretty good idea of the shape after all I won’t be flying it in the jet world masters.
Old 11-18-2019, 09:57 AM
  #155
Canadian Man
Canadian Man's Avatar
Thanks again Dave for the pictures! So when you take the canopy off of the airframe do the 2 consoles come with the canopy?
It looks like the rear console is slipped into slots into the silver canopy insert.
Thank you.
Jonathan.
Old 11-18-2019, 10:21 AM
  #156
Dave Wilshere
Yes, I fixed the consul and panel in the canopy frame. It stands on the two panels when it’s off. Normal operation of the model does not require canopy removal. I used a length of 20 swg piano wire glued to the back of the panel to support the front one. The rear the fibreglass consul was trimmed to fit between the canopy frame. Initially I silicon glued both in, but it did not adhere well, so I used a thin bead of hysol that can be cut if they have to come out at any time
Dave
Old 12-03-2019, 09:10 AM
  #157
Canadian Man
Old 12-05-2019, 01:04 PM
  #158
Canadian Man
Old 12-07-2019, 06:09 AM
  #159
Canadian Man
Old 12-12-2019, 07:15 PM
  #160
Canadian Man
Old 12-13-2019, 01:12 PM
  #161
Dave Wilshere
Jon
If you still have the model, I’d suggest you change the tank overflow tube so that the Tyron loops up first before going out the overflow fitting. The way you have it it dribble fuel constantly when full. it will need a little more tub trimming, but it’s worth the time.
Dave
Old 12-16-2019, 09:18 AM
  #162
Canadian Man
Originally Posted by Dave Wilshere
Jon
Dave
Perfect! Thanks for the tip Dave. I do still have it.
Old 12-17-2019, 02:20 AM
  #163
Dave Wilshere
2nd of two pilots specially made by Wilson at Tailored Pilots to suit the L-39
Old 02-01-2020, 05:48 AM
  #164
Dave Wilshere
Done. We just completed the test runs on the turbine and final set up. Just need weather now.
Electron gear, JR 8931NX servos. Powerbox Mercury, JR 28X, JetCat P-220Rxi
Canadian Man (02-03-2020)
Old 05-30-2020, 01:56 PM
  #165
Canadian Man
Maiden Flight complete!
Old 06-02-2020, 06:21 AM
  #166
Canadian Man
Default Flameout!
Stressful ending to the 3rd flight!
Old 06-02-2020, 10:27 AM
  #167
Pierrot57
Hi,
i’m looking for main air cylinder, if someone can help me..
Best Regards
Old 08-19-2020, 06:53 AM
  #168
Canadian Man
4th flight video. Such a treat to fly!
