Telemetry?
Yes and no. I originally set it for 1500 cause I have a 1.5l tank but that set the alarm off about halfway thru my flight so I played with it till I got it to the point where it goes off after my normally flight with 2 go around which leaves about enough fuel for a gear pass and 2 more go arounds It consistently comes down at the same point. What I don't know is if different size pumps change the values this is on a k45
I am waiting for mine to be delivered, but I think you will find that the unit has at least two adjustable parameters: usable fuel and pump factor. The first will be the fuel you can pump out after you have filled the tank - normally there will be some fuel left as it is virtually impossible to get it all out. Especially when you are not deliberately tilting the plane to extract the last drop. The latter will be a factor/number which you can change and thereby 'calibrate' your setup. This is done by doing a normal flight and then comparing the telemetry 'estimate' of the fuel remaining with the 'actual' fuel remaining. Depending on the difference (if there is), you then either increase or decrease the factor/number until the estimate and the actual is the same.
If this is indeed how this unit works, then the pump factor will pretty much be the same on all the same engines (ie. always the same if you use a 45 etc.) This way you don't have to fudge the tank size/usable fuel, but always enter the correct fuel pertaining to your model into the telemetry setup. Once we know for sure, we can collaborate and publish a list of pump factors for the various KingTech engines using the new ECU's, which will be very helpful for anyone wanting a reliable/close starting point.
Cheers,
Jan
Cheers,
Jan
#33
Sounds like it works very similar to the Xicoy unit...
Please let us know what pump factor you end up with on your 45 (using your actual usable fuel volume - not an adjusted volume to end up with the right fuel remaining telemetry read out). In other words, don't fudge the tank volume to make the telemetry work - calibrate the unit by adjusting the pump volume until the telemetry result is correct. That way we will have a proper pump factor for a 45 that everyone can use - regardsless of the actual tank size/usable fuel volume our models have.
Cheers,
Jan
#36
The short answer is YES, but...
Cheers,
Jan
#37
Has anyone tried to use the Kingtech KT Telemetry module with Spectrum DX18 radio? I purchased the unit to use instead of the GSU on start up. I have a three sheet instruction and I have followed it to the letter, however, I have not been able to get the unit to work. I am using a DX18 transmitter/ Powerbox Royal SRS w/ DSMX satellites/ Spektrum TM1000 telemetry module/ and the Kingtech K-180G turbine and ECU. All of this is less than a month old. I can connect the telemetry module to other receivers, how ever, when trying to add the Kingtech telemetry module, no data is transmitted from the Kingtech telemetry module.
If any one out there can lend a hand, I would greatly appreciate it. My first jet should be delivered in a week or two, and I would like to install this in this jet.
Thanks for any assistance!
Jake
Jake
#43
I have the exact setup as you do, works flawless.
When you say you are not getting data from the KT telemetry are you sure its only KT? Have you tried others? Did you bind the TM1000 is correct order?
-Push the bind button on the TM1000 then power up your Royal SRS
-Go to TX menu in Royal and put it in bind mode
-bind your TX
-Turn off your royal SRS
-goto your Telemetry screen on DX18 and add turbine
-now power down the TX
-power up everything now.
With spektrum you dont have to change anything in the ECU telemetry menu, but you can still change your fuel amount and pump factor there..
as for cables..yes use the supplied 4 pin cable. If you take a close look, the leads are reversed on the other end of the plug. Unlike spektrum both ends are the same.I am using the supplied spektrum 4 pin cable daisy chained into my G force sensor with no issues.
-bind your TX
#44
Hi AARONFORTH,
Thank you very much for the reply! Quick question, the Spektrum TM connects to the Power Box via the with the data port using the JR to mini 3 pin connector cable. Then after I have establised the bind, I connect the Kingtech TM to the Spektrum TM via the suppiled x-bus cable from Kingtech. Is this correct?
Thank you for the assistance!
Jake
Jake
#45
AARONFORTH,
I just followed your instructions and my system came alive and my telemetry from the Kingtech is working perfectly!! Awesome! Thank you for your assistance! This was a big help!
My new jet is soon to be delivered and I am looking forward to installing the system and getting the model up and running!
Jake
Jake
#47
Just a quick note.
You have to make up a Y harness to get full telemetry from your royal srs. There is only one 4 pin spectrum port on the royal and KT . So make a Y harness and plug it into the tm1000. .from there plug your KT cable into it for the turbine. Other end you use a normal spektrum cabe to the royal
Make sense?
You have to make this Y harness...spektrum does not sell this.
I did see one on ebay some other company was making. If you buy one make sure it's the 4 pin NOT 3 pin telemetry cable
Make sense?
#50
There is no printed instructions that I know of.
Jr style plug (3 pin) plugs into the GSU port on ECU. The other end plugs into the telemetry module.
Spektrum cable that is supplied (4 pin) plugs into the telemetry module. The other end plugs into your TM1000.
Go into your telemetry menu in your DX9 and select turbine.
Then bind your TM1000 and your RX.
When you power up your system after binding you should see telemetry on your DX9.
You can also plug in your GSU and go to radio menu. From there you can select your fuel perimeters.
Don't worry about not seeing a Spektrum selection. (Not required for Spektrum )
Hope this helps
Hope this helps
